Решено Расшифровка UEFI BIOS POST CODE Card Debug
Тема в разделе "Технические вопросы связанные с работой персонального компьютера", создана пользователем sergludmila, 25 дек 2017.
    Расшифровка UEFI BIOS POST CODE Card Debug материнской платы GIGABYTE H61
    kuzmichw, Callu, Anatos и 3 другим нравится это.
  2. @BLACK@
    Asus Debug Codes
    00 - Not used
    01 - Power on. Reset type detection (soft/hard).
    02 - AP initialization before microcode loading
    03 - System Agent initialization before microcode loading
    04 - PCH initialization before microcode loading
    05 - OEM initialization before microcode loading
    06 - Microcode loading
    07 - AP initialization after microcode loading
    08 - System Agent initialization after microcode loading
    09 - PCH initialization after microcode loading
    0A - OEM initialization after microcode loading
    0B - Cache initialization
    0C – 0D - Reserved for future AMI SEC error codes
    0E - Microcode not found
    0F - Microcode not loaded
    10 - PEI Core is started
    11 – 14 - Pre-memory CPU initialization is started
    15 – 18 - Pre-memory System Agent initialization is started
    19 – 1C - Pre-memory PCH initialization is started
    1D – 2A - OEM pre-memory initialization codes
    2B – 2F - Memory initialization
    30 - Reserved for ASL (see ASL Status Codes section below)
    31 - Memory Installed
    32 – 36 - CPU post-memory initialization
    37 – 3A - Post-Memory System Agent initialization is started
    3B – 3E - Post-Memory PCH initialization is started
    3F – 4E - OEM post memory initialization codes
    4F - DXE IPL is started
    50 – 53 - Memory initialization error. Invalid memory type or incompatible memory speed
    54 - Unspecified memory initialization error
    55 - Memory not installed
    56 - Invalid CPU type or Speed
    57 - CPU mismatch
    58 - CPU self test failed or possible CPU cache error
    59 - CPU micro-code is not found or micro-code update is failed
    5A - Internal CPU error
    5B - Reset PPI is not available
    5C – 5F - Reserved for future AMI error codes
    E0 - S3 Resume is stared (S3 Resume PPI is called by the DXE IPL)
    E1 - S3 Boot Script execution
    E2 - Video repost
    E3 - OS S3 wake vector call
    E4 – E7 - Reserved for future AMI progress codes
    E8 - S3 Resume Failed
    E9 - S3 Resume PPI not Found
    EA - S3 Resume Boot Script Error
    EB - S3 OS Wake Error
    EC – EF - Reserved for future AMI error codes
    F0 - Recovery condition triggered by firmware (Auto recovery)
    F1 - Recovery condition triggered by user (Forced recovery)
    F2 - Recovery process started
    F3 - Recovery firmware image is found
    F4 - Recovery firmware image is loaded
    F5-F7 - Reserved for future AMI progress codes
    F8 - Recovery PPI is not available
    F9 - Recovery capsule is not found
    FA - Invalid recovery capsule
    FB-FF - Reserved for future AMI error codes
    60 - DXE Core is started
    61 - NVRAM initialization
    62 - Installation of the PCH Runtime Services
    63 – 67 - CPU DXE initialization is started
    68 - PCI host bridge initialization
    69 - System Agent DXE initialization is started
    6A - System Agent DXE SMM initialization is started
    6B – 6F - System Agent DXE initialization (System Agent module specific)
    70 - PCH DXE initialization is started
    71 - PCH DXE SMM initialization is started
    72 - PCH devices initialization
    73 – 77 - PCH DXE Initialization (PCH module specific)
    78 - ACPI module initialization
    79 - CSM initialization
    7A – 7F - Reserved for future AMI DXE codes
    80 – 8F - OEM DXE initialization codes
    90 - Boot Device Selection (BDS) phase is started
    91 - Driver connecting is started
    92 - PCI Bus initialization is started
    93 - PCI Bus Hot Plug Controller Initialization
    94 - PCI Bus Enumeration
    95 - PCI Bus Request Resources
    96 - PCI Bus Assign Resources
    97 - Console Output devices connect
    98 - Console input devices connect
    99 - Super IO Initialization
    9A - USB initialization is started
    9B - USB Reset
    9C - USB Detect
    9D - USB Enable
    9E – 9F - Reserved for future AMI codes
    A0 - IDE initialization is started
    A1 - IDE Reset
    A2 - IDE Detect
    A3 - IDE Enable
    A4 - SCSI initialization is started
    A5 - SCSI Reset
    A6 - SCSI Detect
    A7 - SCSI Enable
    A8 - Setup Verifying Password
    A9 - Start of Setup
    AA - Reserved for ASL (see ASL Status Codes section below)*
    AB - Setup Input Wait
    AC - Reserved for ASL (see ASL Status Codes section below)
    AD - Ready To Boot event
    AE - Legacy Boot event
    AF - Exit Boot Services event
    B0 - Runtime Set Virtual Address MAP Begin
    B1 - Runtime Set Virtual Address MAP End
    B2 - Legacy Option ROM Initialization
    B3 - System Reset
    B4 - USB hot plug
    B5 - PCI bus hot plug
    B6 - Clean-up of NVRAM
    B7 - Configuration Reset (reset of NVRAM settings)
    B8– BF - Reserved for future AMI codes
    C0– CF - OEM BDS initialization codes
    D0 - CPU initialization error
    D1 - System Agent initialization error
    D2 - PCH initialization error
    D3 - Some of the Architectural Protocols are not available
    D4 - PCI resource allocation error. Out of Resources
    D5 - No Space for Legacy Option ROM
    D6 - No Console Output Devices are found
    D7 - No Console Input Devices are found
    D8 - Invalid password
    D9 - Error loading Boot Option (LoadImage returned error
    DA - Boot Option is failed (StartImage returned error)
    DB - Flash update is failed
    DC - Reset protocol is not available
    *ASL Status Codes
    01 - System is entering S1 sleep state
    02 - System is entering S2 sleep state
    03 - System is entering S3 sleep state
    04 - System is entering S4 sleep state
    05 - System is entering S5 sleep state
    10 - System is waking up from the S1 sleep state
    20 - System is waking up from the S2 sleep state
    30 - System is waking up from the S3 sleep state
    40 - System is waking up from the S4 sleep state
    AC - System has transitioned into ACPI mode. Interrupt controller is in PIC mode
    AA - System has transitioned into ACPI mode. Interrupt controller is in APIC mode
    --- Сообщения объединены, 21 ноя 2022, Дата первого сообщения: 6 апр 2020 ---
    Основные Qcode / Q-code / Post коды для плат ASUS
    Если на дисплее вашей платы отобразился Q-Code, вы можете обратиться к таблице ниже и ознакомиться с описанием Qcode и статуса системы.
    QCode / Q-codeОписание
    00Не используется
    01Включено. Обнаружен сброс параметров (программный/аппаратный).
    02AP инициализация перед загрузкой микрокода
    03Инициализация системного агента перед загрузкой микрокода
    04PCH инициализация перед загрузкой микрокода
    06Загрузка микрокода
    07AP инициализация после загрузки микрокода
    08Инициализация системного агента после загрузки микрокода
    09PCH инициализация после загрузки микрокода
    0AИнициализация после загрузки микрокода
    0BИнициализация Кэша
    0C-0DЗарезервировано для будущих кодов ошибок AMI SEC.
    0EМикрокод не найден
    0FМикрокод не загружен
    10PEI Core запущен
    11-14Запущена инициализация CPU до памяти
    15-18Предварительная инициализация системного агента памяти запущена
    19-1CЗапущена инициализация PCH памяти
    2B-2FИнициализация памяти запущена
    29Тренинг памяти (только на серии плат X299)
    30Зарезервировано для ASL
    31Установлена память
    32-36CPU инициализация памяти
    37-3AЗапущена инициализация системного агента после памяти
    3B-3EИнициализация PCH после запуска памяти
    4FЗапущена DXE IPL
    50-53Ошибка инициализации памяти. Неверный тип памяти или несовместимая скорость памяти
    54Неопределенная ошибка инициализации памяти
    55Память не установлена
    56Неверный тип процессора или скорость
    57Несоответствие процессора
    58Сбой самопроверки процессора или возможная ошибка кэша
    59Микрокод ЦП не найден или обновление микрокода не выполнено
    5AОшибка встроенного процессора
    5BСброс PPI недоступен
    5C-5FЗарезервировано для будущих кодов ошибок AMI
    E0S3 возобновление запуска (S3 возобновление PPI вызывается DUX IPL)
    E1S3 выполнение загрузочного скрипта
    E2Видео репост
    E3OS S3 вектор вызова
    E4-E7Зарезервировано для будущих кодов прогресса AMI
    E8S3 ошибка резюме
    E9S3 резюме PPI не найдено
    EAS3 ошибка загрузочного скрипта
    EBS3 OS Wake ошибка
    EC-EFЗарезервировано для будущих кодов ошибок AMI
    F0Состояние восстановления вызвано прошивкой (Авто восстановление)
    F1Состояние восстановления, вызванное пользователем (принудительное восстановление)
    F2Процесс восстановления начался
    F3Образ прошивки восстановления найден
    F4Загружен образ восстановления
    F5-F7Зарезервировано для будущих кодов прогресса AMI
    F8Восстановление PPI недоступно
    F9Капсула восстановления не найдена
    FAНеверная капсула восстановления
    FB-FFЗарезервировано для будущих кодов ошибок AMI
    60DXE Core запущен
    61NVRAM инициализация
    62Установка PCH Runtime Services
    63-67Процесс инициализации DXE запущен
    68Инициализация моста хоста PCI
    69Инициализация DXE системного агента запущена
    6AИнициализация системного агента DXE SMM запущена
    6B-6FИнициализация DXE системного агента (зависит от модуля системного агента)
    70Начата инициализация PCH DXE
    71Инициализация PCH DXE SMM запущена
    72Инициализация устройств PCH
    73-77Инициализация PCH DXE (PCH модуль)
    78Инициализация модуля ACPI
    79CSM инициализация
    7A-7FЗарезервировано для будущих кодов AMI DXE
    90Начата фаза выбора загрузочного устройства (BDS)
    91Подключение драйвера запущено
    92Инициализация шины PCI начата
    93Инициализация контроллера горячей замены шины PCI
    94Перечисление шины PCI
    95Ресурсы для запроса шины PCI
    96Ресурсы шины PCI
    97Устройства консольного вывода подключаются
    98Подключите консольные устройства ввода
    99Инициализация Super IO
    9AUSB запуск инициализации
    9BUSB сброс
    9CUSB обнаружен
    9DUSB Вкл
    9E-9FЗарезервировано для будущих кодов AMI
    A0IDE запуск инициализации
    A1IDE сброс
    A2IDE обнаружен
    A3IDE Вкл
    A4SCSI запуск инициализации
    A5SCSI сброс
    A6SCSI обнаружен
    A7SCSI Вкл
    A8Настройка Проверочного пароля
    A9Начало настройки
    AAЗарезервировано для ASL
    ABНастройка входа ожидания
    ACЗарезервировано для ASL
    ADГотов к загрузке
    AEСобытие Legacy Boot
    AFСобытие Exit Boot Services
    B0Запуск настройки виртуального адреса MAP начат
    B1Запуск настройки виртуального адреса MAP завершено
    B2Инициализация устаревшего дополнительного ПЗУ
    B3Сброс системы
    B4USB горячее подключение
    B5замена шины PCI
    B6Очистка NVRAM
    B7Сброс конфигурации (сброс настроек NVRAM)
    B8-BFЗарезервировано для будущих кодов AMI
    D0CPU ошибка инициализации
    D1Ошибка инициализации системного агента
    D2PCH ошибка инициализации
    D3Некоторые из архитектурных протоколов недоступны
    D4Ошибка выделения ресурсов PCI. Вне ресурсов
    D5Нет места для устаревшего дополнительного ПЗУ
    D6Устройства консольного вывода не найдены
    D7Устройства консольного ввода не найдены
    D8Неверный пароль
    D9Ошибка загрузки Boot Option (ошибка возврата LoadImage)
    DAНе удалось запустить загрузочное устройство
    DBНе удалось обновить Flash
    DCСброс протокола недоступен
    Callu, Ruso, kuzmichw и ещё 1-му нравится это.
