UP6182 Нет дежурки
Тема в разделе "Технические вопросы связанные с работой ноутбука", создана пользователем leonid001, 27 май 2024.
    ноутбук DNS E7130
    6-71-B5130-D02 GP
    Нет дежурных напряжений 3.3в и 5в. Дежурка на м/с UP6182.
    LDO3 - 3.3v
    LDO5 - 5v
    EN0 - 3.3v
    SKIP SEL - 5v
    VIN - 19v
    VCLK - 2v
    Каких напряжений не хватает , что бы появились дежурные 5в и 3.3в.
    UP6182 заменил на новую.
    При подключении платы к питанию ток потребления 0.140А и постепенно падает до 0.040А.
    • UP6182.7z
      UP6182.7z
      18,2 КБ
      4
    • UP6182.7z
      UP6182.7z
      18,2 КБ
      5
    Enable and Soft Start
    EN0 is the control pin of VREG5, VREG3 and VREF
    regulators. Connect this node to GND disables
    three regulators and decrease the shutdown supply current
    to 10uA. Connect this node to 3.3V or 5V will turn the
    three regulators on to standby mode. Two SMPSs become
    ready to enable at this standby mode. The uP6182 has an
    internal 1.6 ms output voltage soft start for each channel.
    When the ENx pin becomes high level, an internal SSD
    begins ramping up the reference voltage to the reference
    voltage of Pwm. The uP6182 shares one SS with both
    channels, if ENx pin becomes high level while another
    channel is starting up, soft start is postponed until another
    channel soft start has completed. If both of EN1 and EN2
    become high level at a same time (within 60 us), both
    channels start up at 1.6ms soft start time.
    POK
    The uP6182 has one POK output indicator, when both
    SMPS outputs are within the targets. The POK function is
    activated with 2ms delay after ENx goes high. If the
    output voltage is within +/-5% of the target value, internal
    comparators detect power good state and the POK signal
    becomes high after 510µs delay. Therefore POK goes high
    around 2.5ms after ENx goes high. If the output voltage
    goes outside of +/-10% of the target value, the POK signal
    becomes low after 2µs delay. The POK output is an open
    drain output and is needed to be pulled up to output voltage
    source.
    А по проще может кто объяснит как обойти этот плавный запуск или дайте с сылку. Буду благодарен.
  5. vvasin
    VREF проверь. 2 В должно быть по даташиту. ну и всю обвязку шимки
  6. Andreo
    Отстань от дежурки , микруха у тебя и старая скорей всего рабочая, смотри что садит ее или не дает запуск ее , , по дросселям дежурки сопротивление какое вообще и по другим дросселям , ресет проца есть , слипы поднимаются ?
