Решено K73Sd No VSUS_ON signal
Тема в разделе "Технические вопросы связанные с работой ноутбука", создана пользователем sandro123, 26 окт 2015.
    sandro123
    sandro123 Участник форума
    Italy
    Hi,
    I ask any suggestion to locate the problem
    no have VSUS_ON.
    0,06A Current
    Already tested:
    KBC
    Bios
    charger IC
    3,3V 5V IC
    Measurements:
    EC_RST# 3,3V
    PM_SLP_SUS # 0V
    SUS_PWRGD 0V
    that another check?
    The bios in this system is not powered, only when it is present VSUS_ON
    Thanks for any tips
    • K73SD_RG.pdf
      K73SD_RG.pdf
      686,6 КБ
      26
      114,1 КБ
      14
    you have 5 V_ALW and 3/3 V_ALW ? , what is the voltage on the power button ? what is the resistance pin VSUS_ON ?
    sandro123
    Italy
    yes, have all ALW voltage.
    3,3V on power button.
    VSUS_ON line is good, >1K
    if force VSUS_ON (external 3,3V) any VS voltage working fine.
    thanks for reply
    KBC good ? , road underneath is not rotten ? EC_RSMRST# = 3.3V ?
    Код:
    What are the conditions that would have to comply with the cartoon gave the command to start
    sandro123
    Italy
    KBC replaced.
    in this motherboard, the system is a little different.
    SPI eeprom no supply with same voltage of EC, but supply by 3,3VS.
    what the EC_RSMRST# = 3.3V ? is EC_RST# ?
    thanks
    sandro123
    Italy
    EC_RST# 3,3V good
    PCH----
    32Khz ok
    RTCRST# 3,3V good
    not find in boardview the PM_DPWROK signal (4)
    EC is 8572E
    sandro123
    Italy
    boardview
    • K73SD_2.3.rar
      K73SD_2.3.rar
      152,3 КБ
      16
    Compare this scheme is very similar
    sandro123
    Italy
    Thanks for find similar motherboard.
    find the problems.
    AC_IN_OC# signal.
    now continue the analysis for complete solving.
    sandro123
    Italy
    solved
    replaced charger ic 51740.
    thanks for support
    СервисКомп и Гавр нравится это.
