Welcome to LCD Repair Guide! This is " V4.0- Collection of LCD & LED Television Repair Tips " ebook. The guide is easy to use and straight to the point to let you learn or solve your TV problems. As usual, the Collection of LED LCD TV Repair Tips V4.0 guide included LCD & LED TV repair tips. NOT only that, it also cover three main sections on LCD TV. They are:
1) Power Supply Board/IP Board (Inverter Power Supply Board)
2) Mainboard
3) T-CON Board (LCD Controller Board or Timing Control Board)
4) LCD LED Panel Replacement
I believe that, after you read this V4.0 ebook, you will quickly go to your dustbin or garbage to take back the damage Main board or T-con Board. After that re-check the boards and maybe you can bring back the board/s to life.
If you're a repairer or hobbyist in TV repair, then you want to improve your skills on LCD & LED TV repair, so just ask yourself some questions:
Do you know how to test the Main board besides the voltages and signals tests?
Do you know how to Bypass the LCD TV Inverter OVP Protection to let you repair the inverter board in components level?
Do you know how to choose the compatible or equivalent Flash Memory & EEPROM IC for the TV & Monitor Main board?
Do you know how the T-CON board GAMMA & Vcom voltages generated?
Do you know the method on how to find the LCD LED TV Panel replacement?
Do you know how to test the Timing Control circuit (Included DC-DC [this content is inside the V3.0 ebook] and their GAMMA sections) in Main Board, T-CON Board or Built-in LCD/LED Panel?
All the above questions, you can find their answer inside this V4.0- Collection of LCD & LED TV Repair Tips ebook. Not only that, it also cover lots of valuable information inside. For example:
LCD & LED TV Repair Tips (They are difference contents than V1, V2 & V3 ebooks)
How to Isolate the LCD TV problem fast!
Another Main Board Secret Repair Tips Revealed!
How to Find a Substitution of SPI Flash Memory and EEPROM ICs in LCD LED TV and Monitor
The Serial SPI Flash Memory Substitute/Compatible List
What is LED Driver in LED TV?
LED Backlight Repair Tips for LED TV
How to Bypass LCD TV Inverter Board Shutdown Backlight Problem- Inverter IC List!
The Method of How to Find LCD & LED TV Panel/Screen as a Replacement or Equivalent!
The T-CON Board
The Importance of Checking GAMMA & Vcom Voltages inside T-CON Board
How to GAMMA Channels Voltages and Vcom (VCM) Voltages Generated?
What will Happen When Vcom/VCM voltage missing?
How to Know the GAMMA Channels Voltages Normal or Abnormal?
Why After Replaced the AS15-G to AS15-HG (or AS15-G to AS15-F) GAMMA IC the TV Still has Problem?
Various of T-CON Board Testing Points and Their Symptom When Voltages Fail to Appears
Repair Case Study for T-CON Board
T-CON Board Repair Tips
And more!
Новые покупки (Складчина)
LCD/LED TELEVISION REPAIR GUIDE 2023-03-14
